CW with ALS 600
Bob
in SmartSDR CAT
Tried CW for the first time with my ALS 600. Got a lot of clicking during sending.
- Is that noise being transmitted?
- The Ameritron manual says to use the ALC and increase to 500 watts until the ALC light just starts to flash. I don't use the ALC in SSB
- Is there a good video explaining how to use CW with this amp? Thanks you
Many thanks. I will check settings and play!😀
Bob
W1AGC
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsQuestions
- What was your CW delay set to? The delay is how long the radio stays in TX after a CW Element is sent. I would try increasing that value.
- What speed was your CW?
- What was clicking? The radio or the amplifier
- This is not related to ALC at all, but it is good to follow the manufacturer's guidelines. Most never use the ALC at all (I know myself and my friends don't use it)
Hi Mike
An update:
I believe I am now on the right track.
- I am finding that I am smoothest at about 400ms. It was on 0 before. Is 400 too high?
- My actual speed sending is at 15. I am not sure what. this setting is actually doing but I set it to 17 as in your photo. What am I actually setting, the recive speed? I can't see any changes no matter how it is set.
- Clicking was from the amp and it clicked in between every charater before when I had it set to 0. Now at 400 it only clicks at the start of my cw operating (maybe at the end too but I am too lazy to check) which is a great improvement.
I am assuming that in changing the delay the QSK goes off but the QSK symbol is not going away in the Slice window. Is there any way to get rid of it?
Bob W1AGC
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
