ATU Command, How to Structure?
I am not clear on how to use the "atu start" and the "atu bypass" API commands.
The wiki shows the command structure as "<pre>C14|atu start</pre>", and explains, "there must be a slice designated as the transmitter and the radio transmit state must be READY".
The question is, how can I structure a command to use the Flex internal ATU?
Below is a log of my attempt, but as you can see, it failed.
Alan. WA9WUD
Radio[1]._sendRequest(C5|atu start)
Radio[1]._receiveMessage(R5|0|)
Radio[1]._receiveMessage(S0|interlock tx_client_handle=0x00000000 state=NOT_READY reason= source= tx_allowed=0 amplifier=)
Radio[1]._receiveMessage(S0|interlock tx_client_handle=0x00000000 state=READY reason= source= tx_allowed=1 amplifier=)
Radio[1]._receiveMessage(S516A56AE|interlock acc_txreq_enable=0 rca_txreq_enable=1 acc_tx_enabled=0 tx1_enabled=1 tx2_enabled=0 tx3_enabled=0 tx_delay=30 acc_tx_delay=0 tx1_delay=0 tx2_delay=0 tx3_delay=0 acc_txreq_polarity=0 rca_txreq_polarity=0 timeout=300000)
Radio[1]._receiveMessage(S0|interlock tx_client_handle=0x62F85ACA state=NOT_READY reason= source= tx_allowed=0 amplifier=)
Radio[1]._receiveMessage(M31000003|Interlock is preventing transmission)
dahhh!
Thanks, Dave, WO2X, for the memory jog.
I was MultiFlex, two clients, and did not include a bind client command along with the "atu start" command.
All is good now.
Alan. WA9WUD
