SmartControl and SmartSDR with my 6400M
GM, I am trying to use Smartcontrol Mode with my 6400M. On my 6400M Slice A is at 14.020, and Slice B is 21.010. But for some reason on Smart SDR the computer version on my computer has 15 Meters at the top and also 15 meters on the slice below the A Slice. I just clicked the band 20 meters on slice A in SmarSDR and now for some reason my B slice on the front of the radio turned off. I just hit the RX button on the front of the radio and both the A and B slice is giving me 14.020 for A and 14.021 for B. And both frequency indications is up above on the A slice. I don't really know what to do to get this right, Did I do something wrong on my Flexradio 6400M or is something all fouled up with my settings on SmartSDR on my computer. Right now, I have no idea how to fix this.
Mark Griffin, KB3Z
Like
Comment
Share
Doesn't sound to me like you're in SmartControl mode. Have you some pics or screen shots?
Ed,
Here are two pictures. When I pushed the A Slice button and changed the band to 15 meters. Both A and B changed to 15 meters. That's my problem. I want 20 meters on A and 15 Meters on B.
Mark KB3Z
Ed,
Here is another picture of my SmartSDR Screen. As you can see I have the Frequency Display for Slice A, But there is no B Display on Slice B. As you see there is a B> at the top Right of the screen.
Mark KB3Z
Hi Mark, You are zoomed in too far to see both the A and B slices on screen at the same time. Note that on the right hand side of your SmartSDR screen that there is a "B" and an arrow indicating that the B slice is off-screen. Either zoom out far enough to see both slices, or click on the B with the arrow to center that slice on the display.
I will try that Len. Thanks!
Mark, KB3Z
Len,
I have expanded the slices. But I still get the B> at the top, How can I move it down to slice B? It's not like you can drag it down there.
Mark
Hi Mark, I think that you mean panadapter when you say slice. Close the B slice in the top panadapter and open it in the bottom panadapter. Then you will be able to scroll each panadapter to show slice A and slice B simultaneously.
Do you know of any video's showing someone of getting SmartSDR to work with your radio? Such as moving this, or setting this, so forth and so on? I hate to admit it, but I must be a real dummy when it comes to getting this to work. I assume that I can not change bands by using the front of my 6400M. I assume that I must change frequency and band via SmartSDR?
Mark KB3Z
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Mark
Lots of new user videos here:
The downloadable user guide for the M models is also good at explaining most features.
Hi Mark, as Mike and Neil say. Quick note to short-cut your way to accessing band change (and many other things) on your 6400M: press the frequency read out
you will see this
Press it again to close and return to the SC Mode screen.
- 713 The Flea Market
- 210 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 992 Genius Products
- 331 Shack Infrastructure
- 235 Networking
