SmartSDR v3.4.21 aborts with Unhandled Error (non UI)
m5kvk
m5kvk Member ✭✭
edited March 2023 in SmartSDR for Windows
I've just installed SmartSDR on a Windows 10 machine. When I start it, I get the following and there is no audio. If I click on PC Audio, I get it again, so I infer that it's something to do with audio driver. I ran the steps to manually reinstall the various DAX drivers, but it makes no difference. I also tried deleting the sesions, and even a total reinstall.
Any ideas?
Gareth - M5KVK
    Hi Gareth, If you haven't done so already, try a factory reset after exporting your profiles.
    If that doesn't help, submit a help desk ticket.
    Hi Gareth, I think this is resolved in 3.4.23.
    If after upgrading to 3.4.23 you still have the same issue, please open a support ticket.
  • m5kvk
    m5kvk Member ✭✭
    OK, I tried the following:
    • upgraded to 3.4.23
    • did a factory reset on the radio
    • deleted any potentially conflicting props (voicebanana and com0com)
    • uninstalled 3.4.23 and removed all traces from file system and registry
    • re-installed 3.4.23
    The problem persists, so I'll raise a help-desk ticket
    Incidentally, Smart SDR Mac drives the radio with no problem, so I think we can exclude this.
    Thanks for doing that. Good call on com0com and banana.
    I use both all the time so I doubt they are the conflict.
    Let us know what they find.
