Function Button band up / band down - no rollover
Hi all
i did update to 3.4.21 on 6600M
and
I like the idea of band up and band down function being added to function buttons
BUT
i get unexpected results using them
so the setup is
F1 is Band UP
F2 is Band down
i have two slices open ..slice A and slice B
so i tried band down using F2..and indeed the freq drop down to next lower band freq
so i keep hitting F2 and at one point expected the band to roller from lowest back to highest
NOPE...first thing that happen is Slice B freq went away and B marker goes missing even though panafall is still there...
i reload the profile for two band ssb as before
and
try F1 Band up function
and i get similar response ..slice A does indeed change band
at point of expected band roller over..once again slice B freq goes away
bandup and band down good idea
but
doesnt seem to do roll over when reach the end ...
and
wipeouts other slice
is it my expectation of rollover being wrong ???
and
why did slice B disappear??
and
how do i set it to change slice B and not just slice A?
any insight would be appreciated
Paul K3SF
I opened a support ticket for you.
thank you...
Paul K3SF
I have similar issues with the band up-band down function keys with a 6400M. How is the band up-band down supposed to work?
BJ, k0cwo0 -
You need to be on the latest version of SmartSDR 3.4.21
Mike, the ability to add Band Up/Down shortcuts to the function keys is a new addition just added to the M model radios and the Maestro. V3.4.21 is the first time those shortcuts were available. And I can confirm the behavior being described.
Thanks, and I think there is a bug opened for it based on the first posting.
after some testing wiht my 6600m i still see that this bug is not resolved on version 3.4.24
and
now it seems other function button assignments get randomly assigned to slices
Paul K3SF
- 386 Community Topics
- 652 The Flea Market
- 155 SmartSDR+
- 437 SmartSDR for Mac
- 274 SmartSDR for iOS
- 264 SmartSDR CAT
- 202 DAX
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
- 344 Tuner Genius XL
- 306 Shack Infrastructure
- 215 Networking
- 143 Amateur Radio Interests
