Smartlink
K6JV
K6JV Member ✭✭
Every morning the Maestro has signed out of Smartlink and requires that I sign in. SmartSDR for Windows stays logged in at all times and seldom asks that I log in. Why is this? Running 3.33.33 on Maestro
    What is likely happening is the Maestro is losing a network connection log enough that the SmartLink connection times out. You might see this on WiFi or if something resets in the network.
    This then requires you to re-login .
  • K6JV
    K6JV Member ✭✭
    HI Mike, both the Maestro and Windows machine are hard wired to the router
    Gotcha -- I see the same thing.
    It is still possible that the Maestro lost communication for some reason and this might be internal to the Windows system in the Maestro.
