TGXL v1.1.16 Update
Dear all, I updated to the 1.1.16 version (SO2R version) and cannot calibrate the screen. There is a blute button shown left upper corner, I cannot press it, no response. With the remote utility everything seems to be running fine.
Any suggestions?
No sure if correct, but check this out:
Tuner Genius Firmware Updates (version 1.1.16)
- Screen capturing implemented for service purposes (Ctrl+Alt+P)
- PTT indicator bug fixed (lightning up both A and B when transmitting)
- Improved FLEX integration
- Touchscreen activated / useable for TGXL 3-way models)
- Touchscreen calibration / automatic and via the API
- TGXL 3-way models can switch antennas via the touchscreen
- Fixed FLEX frequency rounding bug
- Fixed the FLEX interlock bug and improved relay switching timing
- Minor bug fixes
The PDF suggests to me that it is the 1x3 TGXL only that has touchscreen activated......?? My 1x3 now works with touch screen to change antennas. There is no mention of the SO2R version having touch screen activation on this update. Perhaps someone with SO2R will correct me and help you out.
Cheers.
Mike.
Good observation Mike!
After update of my TGXL (SO2R version) to v1.1.16, I was presented with blue dots (3 in successive order). I found that it took just a little more than normal finger pressure to activate each dot (I used a tablet pen with a smooth hard tip).
73, Dewey
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI created a support ticket for this, but I suspect it will have to go through 4O3A: support@4O3A.com.
Ok, thanks. Ken already opened up a Flexradio ticket and we were working on a solution which did not solve the problem.
The fw version 1.1.16 update went well on both my TG-XL 1x3's. The touch screens are working great. Many thanks to Flex & 403A!
Butch, KF4HR
- 997 Maestro
