PGXL not connecting to 6600 3.7.28/3.3.33
Upgraded PG & 6600 earlier today and all worked fine. Shut down for a few hours and now PG will not connect to 6600. 6600 appears to be working fine. PGXL shows "manual' on front panel rather than 6600. Same on PGXL utility. PGXL will not key (PTT) on.
Rebooted PGXL, 6600 and computer multiple times - nothing changed.
Device settings on PGXL under "FlexRadio" tab are proper.
Advice please!
Solved - Page 24 of 73 in updated user guide was the solution.
Had to configure from PGXL panel. Touched panel black box area with a pencil eraser and configured to Flex and rebooted PGXL.
All OK.
A long and stressful way to upgrade the utility and firmware.
I just experienced the same scenario - upgraded firmware to 3.7.28 yesterday; no problems, and continued to operate the remainder of the day. Turned on PGXL this morning prior to Wednesday's CWT and discovered there was no communication between my 6600 and the PGXL. Fortunately I found this thread and was able to reconfigure the PGXL back to what it was yesterday, and join the the CWT, albeit late. I read and reread the release notes and found NO mention of this anomaly. I am in complete agreement with the original poster that this is "A long and stressful way to upgrade the utility and firmware." de W3US
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsWe are glad you got it sorted out.
For the future, FlexRadio has a fully staffed technical support team who are well trained and experience with the FlexRadio products as well as being active ham radio operators. They are the best in the world when resolving technical issues.
Save this link for the future: https://helpdesk.flexradio.com/hc/en-us/requests/new
Other than on Mondays, which are super busy, they do respond pretty quickly, usually within hours.
I think you will find this less stressful.
- 997 Maestro
