Does 6400 USB Power Off indicate shutdown is complete?
Pete K6TJ
On shutdown, I'd like to use the Flex's USB to signal when to shut off the 12V DC power supply in a remote setup. In other words, when the remote user turns off the REM_ON, the 12V DC power supply stays on until USB power is turned off. The reason to do this is that the power supply is less likely to be damaged by power line surges, as well as save a little energy. Does the USB turn off only after the Flex 6400 has adequately shut down?
Any updates? Anyone know? How about flex design team?
The engineering team does not monitor this group at all as they are focussed on other issues.
I opened a support ticket for you. You could also use a voltmeter to measure it.
- 391 Community Topics
- 664 The Flea Market
- 157 SmartSDR+
- 187 SmartSDR for Maestro and M models
- 441 SmartSDR for Mac
- 275 SmartSDR for iOS
- 265 SmartSDR CAT
- 206 DAX
- 386 SmartSDR API
- 62 Aurora
- 299 FLEX-8000 Signature Series
- 976 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 471 Remote Operation (SmartLink)
- 819 Peripherals & Station Integration
- 145 Amateur Radio Interests
