WSJT-X / SmartSDR and DIGI mode
N3WWL
N3WWL Member ✭✭
edited January 2023 in Third-Party Software
Flex 6300
SmartSDR v. 2.8.1
WSJT-X v. 2.3.0
JT-65 Image Controller (Easy Simple v. 01B by JW1HDR)
While listening on 80 meters I heard short burst digital signals which turned out to be SSTV. The ops are using WSJT-X set to mode MSK-144 and the Easy Simple program mentioned above to send and receive pictures. I was successfully able to receive pictures, but having difficulty transmitting as SmartSDR automatically switches to DIGI-U and they are using LSB. I have been unsuccessful thus far. My question is...Is there a way to "force" SmartSDR to stay in DIGI-L, rather than it automatically switching to DIGI-U the moment I attempt to transmit a picture? None of the ops are familiar with SmartSDR. Thanks in advance for any help. Happy New Year!
Jay, N3WWL
    This is a WSJTx setting that is sending the command to the radio (the radio doesn't change modes on its own).
    I think this is it
  • David Decoons, wo2x
    Mike is correct. Leaving mode setting to None will allow you to manually select DIGIU or DIGIL. But you lose the ability to have the mode set correctly when clicking on FT4 or FT8 in WSJT-X. You might “chase your tail” when you are not decoding.
  • N3WWL
    N3WWL Member ✭✭
    That's it! Thanks, guys!
    Jay, N3WWL
