TGXL lost IP address
I had my 6600 disconnect today and had to restart radio and PC. Everything started OK but TGXL. I can see my PGXL shows IP address but nothing on TGXL.
Turned TGXL Off for a few min, disconnected LAN cable and power. Still the same issue after TGXL power up. Green and Yellow LED are ON on TGXL side of the LAN and blinking green light at the switch side. Changed port on the switch, no change.
Any tips how to recover TGXL?
Usually when it starts with the default .140 address it is because the TG XL cannot communicate with your router.
You can try a factory reset. Turn off the rear power switch on the TG XL. Hold the front panel OP/Bypass button while turning it on. Continue to hold the button until the screen says Config Reset.
You will need to reconfigure your settings and retrain the tuner for each antenna you use on each band.
Dave, Thank you for suggestion. I was planning to do it this morning but everything came up fine this morning after I shut down everything for the night.
I hope my 6600 is not affected by the bug recently reported on 6300,6500 and 6700.
Last week I had too many times when I do not have any RX or radio going to disconnect. Usually recovering by restart but frequency of these events a bit alarming.
Sergey, KN7K
Almost sounds like possibly something in the network.
The other thing that comes to mind - Ken Wells from Flex found out the new Win 11 22H2 update resets some network and power settings. Might be worth checking the green settings for network adapter are disabled and PC power plan is set to high performance.
Thank you Dave
- 198 SmartSDR+
- 323 Shack Infrastructure
- 228 Networking
