Browser based access to Flex 6400
Carl_G6UJC
Member ✭
in New Ideas
Hi All,
I am a brand new Flex owner and so far, only 2 weeks in, I have been using the default Smart SDR for windows and really like it. But I would like to be able to use the radio at work when I get a moment free, not that these moments exist to a larger degree, but there are times where a few minutes away from the desk would help reset the brain.
So is there a web based solution that can be used, I say web based purely for the fact that the laptop I work on is business owned and so locked down so we cannot install any software.
I don't want to be dragging a second laptop around just to use the radio on an occasional basis, I have done this and can access the radio successfully at work using the "Guest" wifi here.
I have done a search on this site, but I am also a newbie to these sites so could have missed it or formed a search that was duff so not get the results expected back. The only threads seem to be from a long time ago and didnt come to any conclusion.
Any help pointers would be greatly appreciated.
Carl - G6UJC
Carl - G6UJC
Hi Carl.. the short answer is "no... currently the only access is via the SmartSDR app for either Windows or iOS."
If your work permits it, you can always install SmartSDR on the work computer and connect your radio to the internet. V2 and above of the software was specifically designed to support this.
Hi Don,
Thanks for the response, but unfortunately installing anything other than "approved" software on a works laptop is a no-no.
2 laptops it is then.....
cheers
Carl.0
- 681 The Flea Market
- 198 SmartSDR for Maestro and M models
- 99 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
