Flex 6300 SWR intermittent on connection
Remote is Flex 6300. Using SDR v3.2.39 connects with home pc ok. At remote I can reboot Flex 'sometimes' and when apply RF SWR is fine. (20m). If I change bands SWR is thru ceiling. Load used is 50ohm oil bath Dummy load (MFJ). Have changed out jumpers and gone direct to Flex or thru TGXL and PGXL. Other times I reconnect and bad SWR totally. Have changed to wire antenna and also beam but get same 'intermittent' results. Got to be something in Flex.
Can anyone offer advice or help or should I just submit a help ticket? I have total control of power remotely so can operate at the remote including in LAN mode or remote. Issue is same in both LAN (at the rig) or on remote from home.
I saw one suggestion to 'hard reset' the Flex. Think that does require a visit to remote.
Ideas? Tx all in advance
Bill
Make sure you check all your RF jumper cables between components. They are often a source of trouble due to connector issues. I have frequently found them to be the source of intermittent problems. If you find a bad one, replace the connectors or just throw it out so it doesn't find iteself back into your system at a later date.
Pete K1OYQ
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions@Bill If you haven't already, please open a support ticket.
This problem solved. Polyphaser bad in line and bad connection at PL259, MY bad...Flex just doing it's job. Replaced run of coax and poly and that problem gone.
Now the smartlink servers are down and no remote connection during hurricane IAN :-( Not that it would do much good. Remote is still powered at least. Tx for solutions on the first problem guys. Had to work down the line to the bad spot..
Bill
- 714 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
