Are there any smartlink problems ?
Hello,
I use SmartSDR for IOS. My Flex 6600 shows as available, the status is ok, but I can't connect.
After a while I get the message "No response from the SmartLink Server". Are there any problems ?
73, Uwe
DL2ND
    Mike-VA3MW admin
    Answer ✓
    Not that we are aware of.
    Make sure that on the iOS device go to SmartSDR / Settings and make sure that the Connection type is set to Both.
  • Uwe
    Thanks Mike, working again. But didn't work right away. I'm not sure whether the update to the new IOS version and the subsequent SmartSDR update also played a role. Thanks.
