LinearExperts 1.5K and Remote Flex
Anyone know how to set up a LinearExperts 1.5K and a Flex Remote? Really, I don't know how to set up the amplifier remotely to use with my remote 6400. Anybody out there ever figure it out?
There are many ways to do it. One of them is by web control using the RC-1216H. Google it. Basically it acts like a PC and its web interface is fairly easy to use. I'm sure there will be other suggestions so get a few and do some research.
There are at least 3 ways to do it.
- Use serial to Ethernet box and access it remotely. Requires some network skills to redirect ports.
- Have PC on site with access to 1.5k, and access the PC remotely, e.g., by Teamviewer.
- Same as 2 but redirect port of 1.5k to Ethernet, e.g., using VSPE, and use VSPE locally to recover the port.
I tried 3 and it worked but VSPE was not fully reliable. Option 2 was reliable.
Ignacy NO9E
Not having the 1.5k but a 1Kfa and I have tried several solutions. I have found, as Erik, EI4KF suggests, that you take a look at microbits RC-1216H. I have found it to be the most reliabel solution. More info https://www.remoterig.com/wp/?page_id=1010
Gl, Johan, SE3X
- 684 The Flea Market
