Clicking artfact noise on receive above 14.000 mhz? ...is anyone hearing it
All
I am noticing a low level clicking noise on my 6400: sounds like clicking and can see it on the display waterfall...very low level and repeats but randomly... about 2 to 3 kHz wide and does not correspond to filter selection
I've switched ant inputs 1 and 2...tried different ants (Dipole & EFhw) noise is present on both antenna...and on different Pre-Amp settings... I have even swapped out the power supply.
Before I go any further I thought I would just ask.
Please constructive comments only,
Dave / KE1AV
You can rule out your radio by disconnecting your antenna. If it's still present without your antenna attached, then it could be the radio itself or power supply. I would also suggest downloading FTStack and looking at the voltage reading. You could be experiencing low voltage at the radio. A bad power pole connection can cause strange problems.
On the other hand, if it's only present with the antenna connected, you could be picking up RFI from a number of external sources. Regular clicking or popping can occur from an electric fence. Especially if grass around it has grown up close enough for it to short the fence to ground. Post a photo if you can. That might help identify what kind of problem you are having.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptions0 -
Hello Mike,
I will try...
I tried uploading a.MOV but it wouldn't let me...hopefully you can see the cliking noise in the attached
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThat looks like something that is outside your radio.
What happens when you use an antenna port connected to a dummy load?
Agree...can anyone else hear it?
It's coming in on both my antennas, not the dummy load....which is why I was asking if others are hearing it...is it an artifact from WWV at 15.0Mhz?
FYI:
Note to all...others are hearing this too:
As posted on QRZ From WD0BC:
NOTICING 'CLICKING' ACROSS 18 AND 20 METERS....POSSIBLY OTHERS...
IT THIS THE 'CHINESE' OVER HORIZON RADAR ??? OR WHAT?
THANKS
I'm seeing this starting yesterday on 20M. Did you find the source?
@ Doug N1KB… nope have never found a source but am comforted that others hear it too
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
