6600 and Triplexer
ne9u
Member ✭
Is it safe to use a low power 200w triplexer with a 6600m without any additional external filters?
Or are the built in filters adequate?
You should be fine, but we need to know more about your station setup.
If you want to work on 20 and 15M at the same on a Tribander, you don't need a triplexor at all.
Scott,
I use the 6600 with a 500W triplexer and I don't use any external filtering. There is a worksheet available from Flex that will step you through measurements to make sure your particular setup is safe band to band.
73, Pat KØPC
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
