USB operation on 6600
I am presently using a USB controlled 8 relay board to switch antennae on antenna #2.
Can I use another USB controlled 8 relay board to control a different set of antennae for #1 antenna. Since both boards have different serial numbers will I be able to select either board with different programming.
    Answer ✓
    Yes!
    Not a problem at all, however, I did recommend using a powered USB Hub.
  • Dave W5UN
    Dave W5UN Member, Unconfirmed ✭✭
    edited September 2022
    This may not be the right place, but I need help with a custom DB9F to D15M cable to connect my Flex 6700 to my 2K-FA SBE amp. Due to my disability I am unable to construct this custom cable. Is there anyone in the community who would be willing to undertake this project? Of course I will pay for this service.
    de Dave, W5UN
  • Dave W5UN
    Regarding my previous post, I’ve found a way to construct this cable with no soldering required. I can do this!
