My New Monitor Doesn’t Like SmartSDR So Much
I posted this to the FB Flex Radio Users (Unofficial) page also ...
I have a multi-monitor system here and recently purchased a high-end 4K, 32” monitor as my primary display to play games on …
The monitor is very nice and works with everything I throw at it … except … SmartSDR …
When I have SmartSDR displayed on this new monitor the screen goes black after a while and then cycles back to normal all within about 3 seconds ... It does this repeatedly at different intervals for a few seconds ... Not continuously, maybe every 1/2 hour or so … When I move SmartSDR to another 1080P monitor the 4K monitor works fine with whatever else is displayed ... If I move SmartSDR back to the 4K monitor the issue returns ...
All other programs using this new monitor work fine … only when SmartSDR is running on it does this occur ...
I’ve checked the voltage to the monitor (it’s fine), replaced the Display Port to Display Port cable, swapped the cable to another Display port on my graphics card, and even changed to HDMI … I have also turned over-clocking on & off on my PC and tweaked some of the settings on my graphics card … And I’m running the latest device driver for this new monitor …
I can play games on this monitor w/o issue ...
Strange …
I’m running Windows 11 Pro … with a RTX 3090 FE graphics card … AMD 5950X 16 core processor … 64GB of memory …
My 4K screen on my MAC on my Thunderbolt Hub does the same thing but with all applications.
Did you submit a help desk ticket?
I have 3 monitors on my computer. 34 inch 4K Lg and two 1080P 28 inch monitors. No problems nor have I seen the problem you have. All 3 monitors are plugged into the NVDIA 1050 card. I don’t want any video processing done on my CPU. My clock speed runs at 3.9 to 4.0 GHz. 16 mb of RAM. DELL I7-7700 processor. Windows 10.
I am not configured for gaming.
Bill W9JJB
Looks like I've solved this issue ...
It appears the DisplayPort cable provided with the new monitor was either defective or not up to par ...
Anyway, I swapped the provided DisplayPort cable with a new high-end cable and made certain it was seated well on both ends ... the issue appears to have stopped ...
This may be why the provided HDMI cable had issues too???
Anyway, I'm happy again ... until the next issues ... hi hi
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
