SSDR 3.3.32 Install Issue
I've been using 3.3.29 since it first became available with no issues. I upgraded to 3.3.32 and the upgrade went fine and SSDR opened at the end of the upgrade and was working fine. Profiles et. al.
However, I closed SSDR and then reopened and all I get is the file image attached. As long as I keep .32 open all is fine. Close it and I lose it.
I have reverted to .29 did a reset and cold boot then upgraded to .32. Same result. My W11 desktop is up to date. The 6400 is direct ethernet to the desktop and works ok.
I followed the best practices guidelines for the upgrade. I have gone through the process many times today without success.
This is one I've never seen with the many other upgrades over the past 4 years.
Has anyone else experienced this behavior? Anyone have ideas?
W11, I5-11600, 16Gb,
Best Answers
  • Bob K8RC
    Bob K8RC Member ✭✭✭
    Answer ✓
    Are you sure you are using the correct shortcut to re-start .32?
    Installing a new version does not delete the old version. It installs an additional version. This is done to allow use of a remote radio with a different version than the local radio.
    Since the radio has .32 installed, if you start SSDR .29 on your computer it will immediately prompt for a downgrade of the radio.
  • Lionel
    Lionel Member ✭✭✭
    Answer ✓
    AAAHHHHHHHHHHHH!
    Yep, I recall being bit before by this one.
    Thank you, Bob.
