SmartSDR for Mac - Changing Profiles Stops Transmit on External Digital Programs
I am trying to acclimate myself to SmartSDR for Mac after having used SmartSDR for Windows for the past couple of weeks (I've only had the radio a couple of weeks ;) ).
After a couple of false starts with CAT and DAX, I have all of that working... Mostly...
This is pertaining to external digital programs not the built-in FT8 / RTTY functions. I have several profiles, two of which are 160 - 60 m digital and 40 - 10 m digital. I have these set up so I can click a profile without having to go to the VFO and click through different antenna settings. 160 - 60 m uses ANT1 for Tx/Rx and 40 - 10 m uses ANT2 for Tx/Rx. My problem is whenever I switch profiles, I cannot transmit. The rig goes into transmit and the software looks like it's transmitting but I get no carrier out. Nothing has changed as best I can tell from one profile to the next other than the ANTs swapping. I have checked DAX is enabled. Looking at my DAX streams, I'm using the right DAX channel. Nothing changes from one profile to the next. The only way I can get the radio to transmit a carrier is to restart SmartSDR.
I am using the same profiles between SmartSDR for Windows and for Mac. I have changed nothing and I do not have this problem in SmartSDR for Windows.
Thanks,
Joel, W4JBB
You might want to contact the author as he does not monitor the community.
Thanks, Mike. Odd... The link in the software brought me here. I will contact Marcus directly.
Joel - W4JBB
You are correct, odd and, yes, he does direct here.
Andy K3UK
- 407 Community Topics
- 705 The Flea Market
- 204 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
