How does SmartSDR find the Flex Control
Does anyone know how SmartSDR finds the Flex Control. I know that the Flex Control is serial/USB. Mine usually comes up as COM3. The reason I ask is that I am running SmartSDR on a virtual Windors machine on Linux. Everything works good, except SmartSDR doesn't see the Flex Control. I have the Flex Control configured from /dev/ttyACM0 to COM3 on the virtual windors machine. I can see the Flex Control on the virtual machine, I can communicate with it via a serial terminal program...Putty...and DDUTIL can see and communicate with the Flex Control. That is how I am controlling the SmartSDR on the virtual machine now, using DDUTIL. I would like to have the Flex Control attached directly to SmartSDR, but it can't see the Flex Control.
I don't know enough about VM's, but if there is a way to 'mirror' the /tty/USBx port into Windows, it might see it. You need to look and see how hardware ports are mapped via Linux to the VM.
SmartSDR actually finds it by using the actual device name.
I see now what is going on. The FlexControl driver didn't load. On the Virtual machine the FlexControl shows up on COM3 under the name of "Communications Port." On a real windows machine it is "FlexControl USB Control Knob."
I tried loading the FlexControl driver manually and it crashed my Virtual Windows machine very badly. I had to roll back to an older configuration to get it back.
For now I will stick with using DDUTIL with the FlexControl.
- 409 Community Topics
- 705 The Flea Market
- 206 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
