Rapid Bandswitching
Maybe there's an easier way ... I like to have three CW bands displayed on a big screen and hop between them, copying calls which are then labeled on the display. To move from working a station on one band to calling a station on another band I find I need to:
a) turn off the audio on the old slice (speaker icon on slice receiver info display flag)
b) turn on the audio on the new slice
c) move TX to new slice by clicking that icon on the new slice rcvr info display flag
d) activate tuning on the new slice receiver by clicking on new slice frequency indicator bar.
It would be nice if there was a macro or something that would reduce these four mouse clicks to one (Cntl double click the new signal?). I find I sometimes forget to make one of the clicks resulting in either tuning on the wrong band or, worse, transmitting on the wrong band.
6600 using SmartSDR 3.2.39
Thoughts?
It might be possible, if you use say a StreamDeck or a LoupeDeck, as you are able to "stack" instructions the one after the other using the one press of the button. I know this is possible on the LoupeDeck as I use one for similar. e.g. mute slice "A" then unmute slice "b". Easily done, especially with Mac software, as it uses Midi commands, which allow a small delay between instructions within the button press to ensure smooth change.
Might be worth a shot??
Mike.
I use streamdeck to do what you want, one button will do all of that.
Of course its FR Stack doing the work, the streamdeck just calls a series of functions.
It can do a lot more too.
Rich
If you are using the FRStack tool, and also have a FlexControl Knob, set one of your AUX buttons to "Toggle Active Slice."
Now when you use that button to step between your three active slices, FRStack will change everything else, and you can start tuning the active slice with the FlexControl Knob. (I wouldn't be without mine!)
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
