How to Build FlexLib API in Visual Studio 2022?
w1smc
w1smc Member ✭✭
I'm beginning my adventure in Visual Studio & C# and I need to get over this hurdle.
Is there a cheat sheet on how to import the FlexLib set of libraries into Visual Studio and then build them?
Steve / W1SMC
  • Trucker
    Trucker Member ✭✭✭✭
    Answer ✓
    I'm the lazy type and just copy the FlexLib dll's from the latest SmartSDR installation on my pc to a subfolder in my project.
    I copy:
    Flexlib.dll
    Ionic.zip
    util.dll
    Vita.dll
    Then, in my project I make a reference to each one. This is easier than creating a separate project for each dill and compiling them individually. They have to be compiled in a particular order and Visual Studio will complain that you have a reference missing if you don't have them done in a certain order. Be sure you Copy the dll's and not move them. Otherwise, SmartSDR won't work.
  • w1smc
    w1smc Member ✭✭
    Thanks James ... I'll let you know how it works out ...
    Steve / W1SMC
  • w1smc
    w1smc Member ✭✭
    James,
    Your solution works great.
    I also had to add the Flex.UiWpfFramework.
    I did a build on the on the FQAPSAC project by Gary WB8ROL ... started my 6600M ... ran the code & wha-lah ... it connected to my 6600M without issue ...
    Thanks for the assistance with this.
    Steve / W1SMC
  • Trucker
    Trucker Member ✭✭✭✭
    Hi Steve, glad it worked for you. I forgot about the wpf dll. Old age is my only excuse !
    Have fun.
