6400M with N3FJP Log
I am running SmartSDR 3.2.39 and AC Log 7.0.4. No issues.
In AC Log Rig setup, did you choose Flex API?
Any other software running?
Sorry, you're having an issue.
What's the OS your using?
What hardware is in your computer like memory...?
What all is running in the way of software like firewalls, and antivirus...?
I am running both programs and it does not matter what order I start them in so don't think your problem is the programs in use as much as it could be the computer system or network?
Please give us more information so that we can try and help.
All the best, Tom KN4JX
Ed I run focus helper and I do not have the problem he is describing. Is it happening to you whit ACLog?
Hi Tom,
That's the problem I had with ACLog. Focus helper set for ACLog caused it.
Mike, are you running SmartSDR on a pc at the same time as the 6400 screen is enabled? In other words, is multi flex being used?
I am running Win 7. 16 megs RAM. It doesn't matter if I am running both the radio and SmartSDR or just SmartSDR. I did a restart with only smartSDR and ACLog and if I load SmartSDR after ACLog, any click on the SmardSDR screen will close it. It does not crash SmartSDR, it only mins the screen. Ed, I will check on "Focus Helper". Currently, I do not have ACLog interfaced with the Flex0
Ed, Thanks. That did it.
> @ka9ees said:
> @Mike J I turned on focus help once again yesterday. I turned it off again today. It kept me from using the tabs in SmartSDR.0 -
I am exploring adding ACL to my station and would love some tips in advance. I am a subscriber to ACL already as I used it with my old station with an Icom 7610. I really liked it, especially how it automated logging. I used N1MM when contesting, which is rare for me.
Now I am running a Flex station 100% remotely. Here is additional/pertinent information:
Flex 6400 running with SmartSDR on the remote PC.
PGXL and TGXL running with their respective API's on the transmitter site (local) PC and accessed with Google Remote Desktop
Green Heron Controller running on the transmitter site (local) PC and accessed with Google Remote Desktop
For now, all I am looking for is to have ACL get frequency data from the radio for speedy logging. Down the road, I will consider rotor control and other features.
So, I am assuming the most reliable option would be to run ACL on the local PC and access it via Remote Desktop.
Thank you in advance. Feel free to move this note if you feel it would be best posted elsewhere.
I can run it two different ways when operating remotely. One is, as you suggest, having ACLog running on the computer local to the radio and accessed via Remote Desktop or similar (I use TeamViewer).
The other is to run it local to the operator. When doing this, I find that ACLog won't connect using the FlexAPI, so I have to have CAT running and connect that way.
Your setup is very much like mine when operating remotely. When I have enough bandwidth, this works really well. My typical remote operating locations are good for fishing and very poor for cell service...
Thanks Len.
Can you send me how you have CAT set up to work on the local end?
Sure -
I just use COM4 that I normally use for my WoodBoxRadio S-meter. If you don't have a free port, just click the Add... button at the bottom of the CAT screen and then specify that port in the N3FJP Rig Interface. Perhaps something like this:
6 -
Much appreciated, up and running. Easy.
Great, I am glad that you got it going!
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
