How to set DAXIQ center frequency ?
Hello everyone
I use the DAXIQ output of the Flex-6400 with SmartSdr to feed MAP65 but whenever I happen to shift the tuning to the extremes of the band it also changes the central DAXIQ frequency.
I would like to know if there is a way to directly set the center band frequency of the panadpter and maybe to block it so that it does not change even if you shift the tuned frequency.
73 Ermanno / ik7ezn
Best Answers
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Answer ✓
    Not at the rig so can’t test, but maybe set the pan display very wide will keep it centered, rather than shifting.
  • Ken Wells
    Ken Wells Community Manager admin
    Answer ✓
    If you have a spare panadapter, open it without a slice, and link your program to DAX-IQ on THAT panadapter.
    Then set the panadapter width and the center frequency will be the center of the panadapter.
    I have done that with CW Skimmer Server at times in order to keep it stable.
    Answer ✓
    @ik7ezn You can use the Flex API if you can do some computer programming. This would be a good candidate for a Node Red flow.
    This command will center Pan 0 on 14.250 MHz:
    CD30 | display pan s 0x40000000 center=14.250
    Pan 1 is 0x40000001.
    Here is a link to the API Wiki:
    SmartSDR TCP/IP API - SmartSDR Wiki (flexradio.com)
  • ik7ezn
    ik7ezn Member ✭✭
    Ken, thank you . This works. But is there a way to set the center frequency from the keyboard? Currently I move with the mouse but it is not always accurate.
  • John KB4DU
    Highlight the frequency with the mouse, and enter the frequency from the keyboard. Ex. 7 2 0 0
