Flex 6700 2 meter operation with Q5 432 transverter using the transverter post
Terry Erlacher
Terry Erlacher Member ✭✭
How do I use 2 meters on the 6700 when the transverter port is used by a Q5 432 transverter? I understand an amplifier must be used to have useable RF output for two meters.
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    edited December 2021
    Use a Q5 2MLDPA 2 meter Amplifier and this diplexer switch Q5 sells
    http://q5signal.com/index.php?route=product/product&path=64&product_id=74
    it will even allow full duplex operation if you setup the q5 432 for split IF. Read the DIPS PDF for full details.
    http://q5signal.com/image/catalog/DIPS.pdf
  • Terry Erlacher
    Larry, My Q5 L432 is a common IF
  • Larry _ NY8T
    You can change it easily to split IF, the board is labeled, you just have to move a soldered coax to a differant set of pads on the board. I did mine without any instructions, the board is labeled well. If you don't need full duplex, you can leave it set for common IF and it will still do what you want.
    If you want full duplex contact Corey at Q5 and he will send you the BNC cable to mount on the back of the transverter.
  • Terry Erlacher
    Larry, So if i understand correctly , I can daisy chain the 2MLDPA and L432 Tranverter using the Q5 diplexor without having to turn off the 2MLDPA to enable the bypass function? I am using a Comet diplexer to route the transverter to my 70 cm Diamond X50 vertical antenna. The 2 meter output of the Comet Diplexer is used for my Wires X Node transmitter a Yaesu FTM-100
  • Larry _ NY8T
    Correct, this is the solution for the 6700 with only one transverter port. The PDF file shows the diagram how to connect everything.
  • Terry Erlacher
    Larry I ordered the Q5 2MLDPA 2 meter with common IF and remote option. Corey of Q5 Signals confirmed the bypass switching will be done with software. The common IF means I will not have full duplex with the 6700, I have an Icom 9700 when I need to have full duplex capability. 73, Terry KC4DV
