Smart Link not registering
I am trying to use my iPad for remote control. I go to register SmartLink on the home computer but the registration is always unsuccessful. It says 'PTT timeout'. Help anyone?
You do realize, Cy, that when registering SmartLink, one of the steps is to key the mike, tap the key, or assert PTT on the radio's PTT input? Unless you have physical access (via relay or at the radio), you cannot register SmartLink. Hope I'm not stating the obvious.
That's not the problem he's having. I am trying to use my iPad on my local network. It's not connecting via SmartLink.
You cannot connect via SmartLink on your local network if your radio and iPad are on that same network, if that is what you are trying to do - you need to use a different network, maybe tether your cellphone to make it work.
I misstated and should have known better. I should have said. I can't connect my iPad on my home network. For some reason it wants me to sign in again.
VE3TRQ....well, sometimes stating the obvious is the right thing to do! All I had to do was PTT the radio and presto, it works!!
Happy it worked for you, Cy.
Mine's working now. I didn't have to do a thing. @Ted VE3TRQ I had it all wrong.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis video might be good to review as I tried to explain few things and I start right at the beginning.
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
