TGXL Antenna Selection
DonS
DonS Member ✭✭✭
edited December 2021 in Tuner Genius XL
I just received the TGXL 1x3. I assume Port A on the configuration panel refers to the input to the tuner. Do I need to setup for Ant2 and ANT 3 like I did for ANT1? If so I am only able to see ANT1 and ANT2 but not ANT3.
Second item. I have a 43' vertical that needs a tuner for 80m. Whether I try auto tune or manual tune the tuner goes into swr >10. When I try manual it shows swr >10 and the settings go back to 0. There must be a way to manual tune in this situation.
Don - kx9q
  • DonS
    DonS Member ✭✭✭
    Answer ✓
    Finally got it figured out with the help of N7HQ and W9HLQ.
    Don - kx9q
