Message clipping and N1MM voice memory disconnect in SSB contesting
Ignacy
Ignacy Member ✭✭
I edited voice messages for N1MM with Audiocity. They play fine by Audiocity and SmartSDR MON but on an external radio the beginning and the end of each message are clipped by about 0.3 second. Is this normal? Running 6600.
From time to time voice memories in N1MM stop working. The radio is keyed but there is no signal and no movement under TX streaming in DAX. Any workaround? This is fixed by restarting N1MM but then I lose the spots.
Ignacy NO9E
    I think this is an N1MM bug. I had the same thing.
  • Ignacy
    Ignacy Member ✭✭
    Are both bugs: memories stopping or messages truncated, related to N1MM? Is there a solution? How contests stations like K9CT handle the problem?
    Ignacy NO9E
