Software to PTT multiFlex radio
Hi,
we use multiFlex in the shack during contests in a simple in-band setup. Operators sit next to each other and can work on the same band with same antenna (one calls CQ, the other can find callers)...
The main run station has a footswitch, but the radio only accepts a single footswitch. We do have a second footswitch but need some advise how to connect it.
We are looking for a simple solution, even pure software solution is welcome. Needed for this week's CQWW SSB.
Thanks and 73
Andy
KU7T
A wye cable with both foot switches in parallel. Or a foot switch and the ptt switch.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsIf you are using MultiFlex, then the 2nd footswitch should go on the 2nd client that I assume has the 2nd headset set to it.
You can hook up a footswitch to that client (PC? Maestro?). If a PC you can use the feature in FRStack for the 2nd foot switch by using a physical USB/ RS232 port. I think this is the schematic I use for FRStack and also SmartSDR for MAC.
- 418 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
