CWTY CW Decode-Send Program with Flex 6600
http://www.hotamateurprograms.com/
Program seems to be cool.
Any instructions how to use it with Flex Radio 6600?
Many good references for it. Developer is unfamiliar with Flex.
Best Answers
Hi Robert, I just went to Options, Select Sound Card and selected DAX Audio RX 1. On the DAX tab of the desired slice, I have 1 selected.
Hi Robert,
I have been using the CWTY program from HotAmateurPrograms.com for receiving only. There is no option to select a DAX TX in the software. I contacted the author about operating the transmit side with a Flex. He told me there is no provision to allow a flex to operate on transmit, and there are no plans for an upgrade or any modification at this time. I find that using Flex CWX in "Live" mode along with CWTY for receive works pretty well.
I think i also have used it with the flex already ...should work as KD0RC shows. But there are 2 Version on the site. CWTY is the more modern interface and i think working slightly better too. And you just need to select the proper virtual sopundacrd as above in that one too.
It may sometimes be a little tricky to get the proper soundcard selected with it...
I Find the CW Decoder program that Len sent a picture of, far superior in performance to CWTY that was talked about in a recent QST article
73 Paul
- 683 The Flea Market
- 968 Genius Products
- 355 Tuner Genius XL
