Which 'DAX Audio RX 1 (... should be selected?
As in the attached screenshot when selecting DAX Audio RX ... for Fldigi PortAudio 4 possible variations are available. From the list immediately displayed and again from a list in MME devices, or again from Windows DirectSound device, or finally from Windows WDM-KS devices. Are they the same device(s) or different? I suspect my playing around with these is the cause of my present difficulties with a permanent device always starting at 100% volume and overloading Fldigi.
Thanks, John
Assuming you have the Flex slice audio set for Dax 1, you should be using “DAX Audio RX 1” - that is the client side of the audio device pair.
Ted, thanks for the response.
Got the 6400 working with FLdigi now, but I'm trying to understand in more detail what is it I'm looking at. Not the least because I may have messed things up initially by selecting the wrong device from the list. My point was intended to be there is more than one "DAX Audio RX 1 ..." in the FLdigi drop-dow menu. There are four places I can select "DAX Audio RX1...". One in the 'main' list. And one in each of the three sublists as shown in the screenshot. Total of four places. I don't know if these are four redundant instances leading to the same device. Or four installations of the same device. Or Four slightly different devices. What would be the effect of selecting each different device? Is there a single right answer?
I believe it’s the one with “(FlexRadio Systems DAX audio)” after it, John. I use Windows only infrequently, preferring Mac and Linux.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis video explains how DAX and CAT work. It might help you out.
Do not use anything with the word 'reserved' in it.
2
- 713 The Flea Market
- 210 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 992 Genius Products
- 331 Shack Infrastructure
- 235 Networking
