Flexx 6400 M
Don  Klier
Don Klier Member ✭✭
edited September 2021 in DAX
Flexx 6400M will not keep dax1 for receive audio
    Don
    There isn't much to go on here, so we will need you to take some time and elaborate further and describe when it works and when it doesn't work.
    SmartSDR Screen shots are very helpful too.
  • Don  Klier
    Don Klier Member ✭✭
    thanks for answering... when i switch bands I always have to select rx audio dax1 even when I shut down and turn radio back same thing tx dax1 always there just rx dax I have to select ( it used to save then ..not since the latest uodate hope that helps thanks again
  • Don  Klier
    Don Klier Member ✭✭
    Ver 3.2.39
  • Don  Klier
    Don Klier Member ✭✭
    Can someone tell whats wrong i have saves all setting.. but they don't show up in the profile where does it save it too?? Tnx
  • Don  Klier
    Don Klier Member ✭✭
    sudenly my dax audio tx (flexradios) dax has disapeared help not in the list any more
  • Don  Klier
    Don Klier Member ✭✭
    Thanks Mike slicemaster did the job. i have to set radio on freq however.. do you by chance havea the same video you send on you tube trying to read from the small screen was hard to see thanks again
    still wonder why it stoped working after 2 years....hi hi all the dax was set tx and rx for dax1
    73 tnx again 73 don W0DJK
    All the videos we have are located on our YouTube channel
    https://www.youtube.com/user/FlexRadioSystems/videos
