Flex6500 + 70 cm Transverter
Dear OMs,
My station was off for 2 years. I used it for 70 cm EME in the past without any issue. Now I try to reactivate it. It shows a behaviour that didn't exist before.
I have a Flex6500 with SDR v3.2.39. I use a transverter (432 / 28 MHz) connected the RX A for receive and XVTR for transmit. It used to work very well.
RX A and 70 cm receive is working fine.
I'm not able to get a transmit signal out of XVTR anymore. I checked it with a spectrum analyser. No tune, no CW or SSB signal is comming out of it.
The transverter (stand alone) Tx is ok too - checked it with a 28 MHz 0 dBm signal from a generator.
My questions: Did something change in the Smart SDR Software or is it my configuration of the rig . . . ?
Thank you in advance !
73 Wolf - DF7KB
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Wolf
There has not been any change in SmartSDR in the transverter area.
You may have a hardware issue, since you measured the RF out of the XVTR port and there is no RF out.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI converted this to a support ticket.
