Antenna Genius running version 3.1.4 continuous issue.....
I have a 40-10m Log and I have a 40m Mono bander
Why do I always have to Go into Configure Device
Then Click Save and Reboot (No Changes) to get access to my 40m Mono bander
It is always defaulting to the Log Periodic
and not showing the 40m Monobander as a choice ????
And yes I am using version 3.1.4 firmware AND I am using Two different 6600 rigs
One connected to port A the other connected to port B
Instead of just one Transceiver
Any help would be greatly appreciated
Steve KG5VK
Best Answers
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Steve
It is supposed to go to your last selected antenna. I would recommend sending an email to support@403a.com. They will get back to you.
Make sure you include these screen shots and the FlexRadio setup screen shot since you are using 2 different radios.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI was, but it is too risky as Alabama's vaccination rate is pretty low.
In order to come home to Canada, I have to have a PCR test to cross the border back into Canada and if I fail that, I can't get over the border. That would not go well.
Steve, look at the picture in your first post. For the second antenna you have the name of the antenna on the right instead of just the bands it is enabled for. Should be just 40m. Something is not right.
Try clearing all selections and save & exit the utility then go back in and choose 40 meters. Also any port that is active (has an antenna) should not be set to none in addition to the bands.
Dave
Thanks I will try that modification
I bet you are right and that will fix it
A second set of eyes always helps 😎
Steve KG5VK
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI won't be going, as it is just a bid too Covid risky since the Alabama vaccination rate is really low and if I should contract it, I won't be able come back to Canada.
I just made that decision about 2 weeks ago.
Thanks for the fast reply
By the way are you going to Huntsville, Alabama's Ham Fest
If so see you there!
Steve
KG5VK
- 692 The Flea Market
- 119 Aurora
