CHANNEL memory 60M
I might be missing the obvious and trying to speed along setting up my 6400. 60 Meters is channels USB. How can I set them up in memory? Smart SDR users manual is not clear on this.
Seems that it assumes that I'm using FM and repeaters and slices and yabba yabba.
How to eliminate the other parameters? Or another hint in SmartSDR was something called PROFILES. Seems more options and maybe friendlier...........dunno
5-channels of 60M frequencies USB 100 Watts of RF. This isn't brain surgery.
Thanks a lot
FRED..........KC4MOP
I believe this shows all the pertinent info:
No this did not answer my question. I know the freqs.
I want to get them in a memory position in Smart SDR so I do not have to keep entering them to call CQ on that band. There is a memory ability in SMARTSDR but it thinks I'm setting up FM repeaters and tones.
I would set them up in FRStack.
You can use the memories. They are general purpose, so you see FM repeater info there as well. Just ignore items that don't apply, and they will work great. I have a mixture of repeater and HF frequencies. To keep them straight, I prefix the name with HF or FM, then sort by name.
Thanks Ed and Len......I'll try the memory app built into smartsdr, and give it a whirl. FRstack is another app that has to be downloaded and now dealing with slices.
It'll take some experimentation and hit and miss to drill down on this.
Fred KC4MOP
Hi Fred,
Sorry I misinterpreted your question. I would like to add that in addition to the memories I have set up profiles for 60 Meters which include TX bandwidth settings so I don't have to set it manually each time I go to 60 Meters.
Geoff AB6BT
Hey Geoff.
No problem at all....I have been looking over the few ways to get 60m in some style of memory and read from SmartSDR that profiles were a much easier approach toward the memory issue. I remember way back with a Flex SDR1000 that when you selected the 60m band the "channels" were already configured. Like set in stone.
Fred
PROFILES are SWEET. I set up 60M under the global tab. Memorizes everything involved with the radio. Microphone brand, EQ, power setting ........amazing
Fred
- 713 The Flea Market
- 210 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 991 Genius Products
- 330 Shack Infrastructure
- 234 Networking
