WSJT-X / SSDR problems. Help needed
I'm having problems getting WSJT-X to work. I have read all of the threads that pertain to this problem but thought I would start a new thread so as not to interfere with them.
pretty much...I'm doing something wrong or have omitted a correct setting. I'll include a screenshot of my settings. If you see anything obvious, please let me know and thank you in advance.
Jeff
KG9LD
  • AA5SH
    AA5SH Member ✭✭
    In WSJT-X in the network server try:
    localhost:4992
    If that doesn't work try it with the ip address in the bottom of the CAT window in Smart SDR (I can barely see it but I think it is this):
    192.168.1.195:4992
    But basically it needs to be the IP address of your Mac then colon the port number in the Smart SDR Cat settings.
    Good Luck
    Michael, AA5SH
  • KG9LD
    KG9LD Member ✭✭
    Michael,
    Thank you. It looks like changing the network server worked!
    I'll stop back here if there is a problem, I don't have time to play right now...
    73's Jeff
