Waterfall Freezed on my New Windows Laptop
Hi, yesterday i have bought my new laptop and today i have installed the latest version of smart sdr, the connection works fine, but when i start SmartSDR and connect my Flex-6300 he waterfall is completly freezed.. the tuning work, if i move the "VFO" i hear the station in band but the spectrum scope and the waterfall is freezed.
i have tried to uninstall and reinstall the aplication but nothing change, If i try to open smartSDR on my desktop PC all works fine…..I don't know how to fix this problem.
Please let me Know. Many Thanks IZ2FOS
Best Answers
Maybe this will help you?
Update to my post. I downloaded the latest Intel 30.0.100.9684 driver and it completely fixed issues seen with the waterfall. Download link for the Intel® Core™ i7-1165G7 Processor (12M Cache, up to 4.70 GHz) https://downloadcenter.intel.com/product/208662/Intel-Core-i7-1165G7-Processor-12M-Cache-up-to-4-70-GHz-
With this driver I no longer needed to disable the Intel(R) Iris(R) Xe Graphics in the control panel for the waterfall to work in the recommended default video settings.
Try this:
Intel has posted a new graphics driver today to replace the BETA version from June 8th.
I have installed it and it seems OK. I had some issues with the install due to windows defender deciding that the exe was a dangerous file. So I downloaded the zip version, unzipped it and did the install.
SSDR is running without problems. I can't test it with games as I don't have any.
This new driver corrects bugs in the original and also fixes a graphics problems in the intel 11th generation processors.
You should check the release notes and ensure your processor version is on the list. Find your processor version in settings/system/about.
Robby/HP3SS
So today stopped by Best Buy and purchased the Dell Inspiron 7506 2n1 Laptop/Tablet, 11th Generation Intel Core i7-1165G7, 16G ram, 512 SSD with the chargeable active pen and touch screen. It only took a short time to set the Dell with SDR software. But once I loaded the SDR software at the recommended 3840 x 2160 display resolution with the scale layout at the recommended 250% the waterfall was freezing or not working what so ever. Everything else worked great except the waterfall. After working on changing the settings I finally got the waterfall to work with the scale layout set at 175%. But it was not perfect and all the fonts in other applications was too small for my old eyes.
After reviewing this discussion and doing research with Intel discussions I tried the two different new drivers released by intel in June and July. These did not fix my issue. I then went into the control panel under Hardware/Device manager/Display adapters and disabled the Intel(R) Iris(R) Xe Graphics. Doing this completely corrected all the waterfall issues at the default 3840 x 2160 display resolution with the scale layout at the recommended 250%. What I found was the only thig this impacted was in tablet mode it would not rotate the screen but for me in tablet mode it still worked great. Once they update the driver for the 11th Generation Intel Core i7-1165G7 it will correct this minor issue.
This laptop/table with touch screen is absolutely wonderful for use with my Flex 6400 as a remote station.1
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
