Urban Beam with 6400
Anyone using an SDA2000 controller with an Urban Beam with their 6400? How did you choose the transceiver since Flex is not listed? And what about the settings for the USB port?
Cy
For Transceiver control, use the Kenwood Transceiver in the SDA200. 9600 Baud.
Alan. WA9WUD
I did that but it is still not tracking.
I am using a USB to RS232 (Tripplite) with the Flex cable but still no joy. Any ideas?
Here is a link to the Flex USB Cable Guide.
SteppIR instructions start on page 12.
Alan. WA9WUD
I found it.
I went to settings but the USB adapter I put in there is not showing up.
Bad or wrong USB FTDI adapter.
You need a USB to RS232 adapter with an FTDI chip in it. The cables Flex sell works great.
Cy
It does work. If you share more details about your setup we can help you through it.
As was said, you need the correct USB/RS232 adapter.
I had to plug the other Flex USB cable end into the SteppIR S12 transceiver adapter cable needed for the SDA2000
Thanks all. I ordered the Flex adapter so let's see if it works
c
Hi All
I got the Flex cable usb to rs232 interface and it works perfectly. The urban beam is tracking. what game changer this is!!!
Congratulations! Glad to hear this!
Yeah, the TrippLite cable uses the PL2303 chipset which does not work. Reason is the PL2303 does not have a way to uniquely identify each cable.
The FTDI chipset has unique serial numbers in each cable so they can always be enumerated properly and remembered by the radio.
2
- 409 Community Topics
- 705 The Flea Market
- 206 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
