CAT not displaying com ports of installed software.
system : flex 6300, Maestro, and win8 desktop.
Have been using above setup for some time now running WSjT-X mmsstv and mmrtty with no problem.
WSJT-x uses TCP 6000. MMsstv and mmrtty use com 4 & 5. Today CAT only recognizes com 116
and TCP 6000. WSJT_X works properly other programs do not.
Under Devices com 4 & 5 are listed along with a lot of other com ports.
Win 10 laptop all com ports show in CAT and programs work properly.
Any suggestions?
Buford, W4HVW
Can you post a picture of your Com ports in Device Manager and SmartSDR CAT? It is possible they changed and if they changed then you will need to adjust WSJTx to match.
Any port greater than 100 is reserved for SmartSDRs use as part of the VSP, so you can ignore them.
Or, you can use SliceMaster to configure things for you.
- 391 Community Topics
- 664 The Flea Market
- 157 SmartSDR+
- 187 SmartSDR for Maestro and M models
- 441 SmartSDR for Mac
- 275 SmartSDR for iOS
- 265 SmartSDR CAT
- 206 DAX
- 386 SmartSDR API
- 61 Aurora
- 299 FLEX-8000 Signature Series
- 974 Maestro
- 949 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 471 Remote Operation (SmartLink)
- 145 Amateur Radio Interests
