6400m Upgraded to fix smart link but still no go
k9bdh
So i understand i can't use the front panel if i upgrade for now which is fine but how does the radio then connect to the smart link server.. I updated to 37 on windows smart sdr and it updated the radio. but then on the front panel when i try to log into Smart SDR i still get the OK button.. How do i get my my 6400m to link to the server when you can't log in on the front panel? I have done a factory reset also after upgrade.
THanks in advance.
k9bdh
THanks in advance.
k9bdh
Use SmartSDR to log into SmartLink.
Flex will have a install method when the Maestro Software will be released I am sure, So I would not worry about it right now.
You could also go back to the version the Maestro control panel is on then it should update fine.
[{"insert":"tried to go back still get the white scteen with the “ok” and thats it\n"}]0
Until Flex updates the software for the Maestro you will not be able to access the radio unless you come in thru a Windows based laptop or desktop that has the latest software release that fixes the SmartLink issues thru windows. Maestro will not work until they get us another "Fix" to access the radio thru the Maestro.
Find and Watch Tim's and Mikes from FLEX video that explains all this, Better then beating a old dead horse to death that just won't work any longer.
- 696 The Flea Market
- 121 Aurora
- 983 Genius Products
