No radio found from LAN
I have had winter break, without using Flex-6400 of mine. And now SmartSDR doesn't find radio.
Connection and cables to the switch should be OK. I am using "Advanced IP Scanner" and it find radio and radio's IP is on. Gives ping nicely too.
I have made white reset to the radio.
I am using professional Microsoft antivirus...
What I will try next ?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI have created a support ticket for you.
The support team will get back to you, but it might be a bit longer than normal.
In the mean time, please describe your LAN setup and what version of SmartSDR you are using.
To prove it isn't a firewall issue, turn off your Windows Defender firewall. If that solves the problem, then it may be that the NIC card on your computer got changed to PUBLIC from PRIVATE. Microsoft has a habit of doing this and if your firewall is turned on for PUBLIC networks, then it can result in the radio not being found.
Thanks. I will.
73s
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
