Many steps to start up Maestron after updating to new softwaer 3.2.31
[{"insert":"Hi\n\nYes the question is be there have been\nso many emerging steps of Marstron\nafter updating to the new software 3.2.31 \nrun Flex 6500.\nBefor updating that it was just to start and it came up after a while to SmartControl Mode that I want a Maestro in.\nNow I have to run step by step every time \nto get to SmartControl mode. I have started the SDR program on the computer and everything else first does not help.\n\nTanks for all the help I can get.\n\n73 de SB6A\/ Pierre\n"}]
Best Answers
On my m series radio when you get to the screen where it says Info/Operate/SmartLink Setup tap on the gear icon in lower left corner. Tap on Auto Connect.
Thanks ... that worked for me ....
I have the same issue ... prior to v3.2.31, my Maestro would automatically connect to my 6700 (assuming it was fully operational of course) without further intervention but now I have to select the 6700 and then select the version of software I want to run in the Maestro.
What is the reason for this change and is there a setting change I can make to enable auto-connect?
Thanks! David G4NRT/Z21NRT
[{"insert":"Thanks David G4NRT for Info. Yes I have the same problem and do not understand the reason either.\nThis problem did not exist in the earlier software. Ver. 3.2.12\nAnd I dont know why the problem appears in the latest verision of the software.\n73 de SB6A\/ Pierre\n"}]0
[{"insert":"Hello\n\nAnd Thanks David for info this work nice now.\n\n73 de SB6A\/Pierre\n"}]0
- 104 Aurora
