multiflex and profile selection
Why if i'm able to connect as multiflex obiousvly with 2 different machines the mic settings are only 1?
smartsdr(used by different pcs or maestro or iphone) follow the last connection settings and every time need change the settings according to the source you connect!
also 2 people are connected on first step they both will have same settings and need change everytime and be sure will not change each other
will be imblemented this bug?
Have you tried selecting different mic or transmit profiles on each computer?
From my experience, this is an on going problem. (One of the many things we have to live with until there are some fixes.)
When I select profiles on my windows computer, those settings will stick. Then when I start up the iPad, it comes up with the settings for the windows computer. The same is true, when I change the profiles on my iPad, those profiles stick when I next use the windows computer.
This is a problem also the same when operating with two different computers/devices connected at the same time.. You have set profiles for each device. Not the best situation.. the work around is you have to be aware of the problem and check settings each time you start up to use your radio.
It would be be better if some settings were stored on the computer rather than in the radio. This way each computer would have the correct profile settings when they are started.
73.. Ken - VE5KC
