CQ WW RTTY with 6400M
Detlef
Hallo, may be somebody know how. In the last CQ WW RTTY I used N1MM with fldigi an my FlexRadio 6400M. I noticed that a strong station reduced the readebility of a weaker one, forced by the AGC. In my case the filter bandwidth is 1.8K and AGC setting is fast, which does not really help. How can I do it better?
73 de DK6OR
73 de DK6OR
The RTTY standard shift used on the ham bands is 170Hz. Narrowing your RX filter to 250 to 300 Hz should help.
Gayle K0FLY
Thank you Gayle. Yes, I ignored the BW Select not to loose the quick change from one signal to another within BW. I must consider.
Stay safe - Detlef DK6OR0
