Windows 10
Can anyone advise me?
Hi: I have win 10 and the Flex 5000A. I'm using PowerSDR by KE9NS. On first run, it will profile the system and find sample rates that are best with the system, and back-up the firmware and database from the radio to the computer. His Flex site has a lot of details and info..
https://www.ke9ns.com/flexpage.html
I hope to hear you on the air soon.. One very popular mode, now, is FT8 and FT4. These are modes within the program WSJT-X .
https://physics.princeton.edu/pulsar/k1jt/wsjtx.html
You'll find these band segments loaded almost all the time.. You will need to make sure the computer clock is accurate to about 2 seconds, though..
Take Care de KB2MEN0 -
You will need a PC with a open PCI slot. Not all PCs now have PCI slots, but most decent PC will run just fine. You will need to add the FireWire , most of the PC geeks do not know what FireWire is. Get a card with a VIA chipset in it, Win10 will recognize the card , then plug the radio in, turn it on. Be REALLY careful that you plug the radio in correctly, if you accidentally get the FW cable upside down, you will wipe out the FW chip in the radio.
Dudley, WA5QPZ
😎I bought 2 of these and they both work great on two separate computers, !!!! 😎https://www.amazon.com/gp/product/B07Q2G79QG/ref%3Dppx_yo_dt_b_asin_title_o05_s01?ie=UTF8&psc=1
😣Other cards that look exactly the same DO NOT work with the FLEX legacy radios on two separate computers 😫
Here is my post on the Flexradio Discussion
