RTTY Issues with V2.6.2
Pat Hoppe
Member ✭
Hello,
I am running V2.6.2 SDR software in my 6600. When I operated in the ARRL RTTY contest, I ran into an issue. Every time I changed bands, the radio stopped transmitting. The logging software sent the text to the radio but the radio did not transmit. If I restarted the SDR software, it worked again. This happens with every band change.
Details:
N1MM+ logging software, 2Tone decoder
2.6.2 SDR software
Flex 6600
It worked in prior contests, not sure what is causing this issue. Any help would be appreciated.
Pat WW9R
Details:
2.6.2 SDR software
Flex 6600
Pat WW9R
2
This happens to me with my SO2R setup and my 6600. Transmitting on radio 1 and decide I will switch bands on radio 2 to see what is happening on a different band. Doing so stops the TX on the first radio and I get a little popup message, see below. It seems as if SSDR does not understand what SO2R operators really do. It's a quirk I've learned to live with it but it would be nice if it could be fixed in a future release.
Tim K9WX
I should have mentioned I am running SSDR 2.4.10. I find a restart of SSDR is not necessary to start transmitting again. But I have learned not to change bands on the second radio mid QSO.
Tim K9WX
Tim,
I was running SO1R - nothing fancy. Band changes locked it up every time. I'll keep investigating.
Pat WW9R0
- 715 The Flea Market
- 218 SmartSDR+
- 469 SmartSDR for Mac
- 130 Aurora
- 994 Genius Products
- 363 Tuner Genius XL
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
