DAX Channel 1 Not Working
Geoff AB6BT
Geoff AB6BT Member ✭✭✭
edited November 2020 in DAX
Running 6400, v2.4.10 Windows 10, 2004. Today WSJT-X, v2.2.2 stopped showing receive level. I had been using DAX channel 1 with no problem. I changed SSDR to use DAX channel 2 and set WSJT-X to likewise use DAX Audio RX 2 and all is well. If I change SSDR and WSJT-X back to channel 1 I again see no receive level in WSJT-X.
Additionally, when I open WSJT-X with channel 1 selected I get:
"Error in sound input
An error opening the audio input device has occurred."
Any ideas out there?
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    I’d look for a Windows update having changed your audio devices.
  • Geoff AB6BT
    Thanks, that's the first place I looked. Everything appeared correct.
    I just switched back to channel 1 on both ends and of course it is working now.
    Operator error or gremlins???
