Qsorder and SO2R setup for SSB?
Hi
I am trying to setup qsorder. For SO1R, I know how to do that but SO2R adds complexity. I would like to record DAX1+TX DAX for slice A and DAX2+TX DAX for slice B.
Do I have to run 2 instances of qsorder?
Can I create 2 Virtual Audio Channel and each using TX DAX as an input?
I am trying to use Voicemeeter...
73 and thanks
Andy, KU7T
Andy, I have run QSOrder in the past. It's a very useful program, but have had issues with it when upgrading so I've had to run an older version of it. I had issues with the MS C++ redistribute and the program not "finding the correct libraries". When it does it's job, it's very cool (when I remember to start it...).
I don't use Voicemeeter, as that might complicate some stuff, but I will share my configs with you to hopefully point you in the right direction. I'm assuming (the limited info I know about Voicemeeter), you want to push all your DAX channels into Voicemeeter and then record 1 output into QSOrder? That's how I would probably set it up the first time around.
For my setup, I run three separate instances of QSOrder on my computer. I copy the executable into three different directories within N1MM so they can all run simultaneously. I created three different notepad files and re-named them DAX1.bat, DAX2.bat, and MIC.bat. I saved the .bat files on my desktop.
Instance 1 records DAX1
Instance 2 records DAX2
Instance 3 records my Mic Input. This is kinda un necessary, but I like line up the audio flies and my voice when creating YouTube videos so I have what my TX is.
Below is Instance 1 config where DAX1 is input #6 when I run qsorder.exe -q from the command prompt. All the rest is basically the same with changing the DAX sound card #, the radio # and the port.
@echo off
cd "c:\Users\AA0Z\Documents\N1MM Logger+\QsoRecording\DAX1"
qsorder.exe -r 1 -C -i 6 -k Z -P 12061
DAX 2 instance is configured like below;
@echo off
cd "c:\Users\AA0Z\Documents\N1MM Logger+\QsoRecording\DAX2"
qsorder.exe -r 2 -C -i 3 -k Z -P 12062
Let me go through the switches.
-r 1 = only listen to radio 1. In my N1MM config -> Hardware tab where you setup your CAT control, I set slice A (COM X) to Radio Nr 1. Slice B (COM Y) is set to Radio Nr 2. Before setting this, if I complete a QSO on Slice A, the program would record both DAX1 and DAX2 and save a file for each, so that's where the Radio Nr in N1MM comes into play. After operating I would have to go through my directory and remove the duplicate recordings with nothing on it.
-C = to record an hour long file of each DAX and save it accordingly. This is a totally separate file. I use this as a backup file if the individual QSO's do not record correctly.
-k Z = hot key is set to Z to instantly record (I've never used this)
-P 12061 = listen to UDP port 12061 from my computer as that's the prompt when to record. Under my Config -> Broadcast Data, I have this configured in the Contacts (with the box checked) 127.0.0.1:12060 127.0.0.1:12061 127.0.0.1:12062 127.0.0.1:12063 127.0.0.1:12064. I'm assuming you don't need this and could just listen to 12060. I probably made this more complicated than it needs to be.
I would assume if you got Voicemeeter to work and mixed these all down to a single output, you wouldn't need to mess with the Radio Nr. Maybe that is fixed in newer versions of QSOrder? Not sure.
I don't know if any of this helps you, but wanted to document it here for future reference and anybody else who was having trouble with QSOrder.
If you want to contact me off list, I'm interested in what you are trying to accomplish with Voicemeeter, so maybe we could find a solution. I'm good on QRZ.com.
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
